82 Mk1 Gti - rear brake and drum replacement issue
(In Topic #211443)
i am currently replacing the rear brake kit and drums on my Mk1.
After successfully Replacing the rear brakes and pressing the inner bearing on the drum into position , I found that the rear drum wouldn't fit over the brake shoes. I tried the old drum also and encountered the same issue.
Any advice here folks or why this might happen?
Im making the assumption that I had all the correct parts in the overhaul kit.
Den
Will it not just fall down again once pressure off of this ?
Will this push the shoes in which will push the shoes in ?
Is there a certain technique of will it just push up by hand ?
Thanks again
Denis
thanks for the help
