2 speed fan connection ?
(In Topic #228271)
Can't find the correct connector
Also I have had the car for a few months … what is this ? What should it look like as this can't be right from the clutch ??
The 2nd pic looks like a bodged re-enforcing plate for where the clutch cable comes through the bulkhead.
Thank you
If you want 2 speed functionality, then you would need the 3 pin switch on the radiator, of you don't then what you have is fine… Just get the new connector and only use the 2 pins that you are now and leave the 3rd alone.
They used the same motor on Golfs, Passats, Jettas…
