1981 Gti Wiring
(In Topic #222260)
I failed to take a picture when taking out the wiring to the fuel gauge sender and fuel pump. I can't work out how to route the wiring now I need to re-install it. The loom has a grommet to take the wires from inside the cabin through to the outside for the wires to connect to the sender and fuel pump. I cannot find the hole where the loom should go!
The picture shows the wires: four uncovered wires come from the main loom and go through the grommet to the two covered pairs which go to the fuel gauge sender (on the left) and the fuel pump (on the right).
Can someone take a photo showing where this goes please? Failing that, a clear description please.
Thanks. Phil Chambers
Phil Chambers
1981 Gti Wiring
Phil Chambers
1981 Gti Wiring
1981 Gti Wiring
1981 Gti Wiring
1981 Gti Wiring
You said it goes through a hole in front of the round disc that gives access to the fuel gauge sender. I have now looked closer and found the hole. That might sound daft but the hole was covered from the underside with tape when the interior was painted. The paint on the tape made it look as if it was solid metal and hid it completely. It was only when I pressed my finger on it that I could feel the tape give and reveal the hole.
Thanks again. Phil
Phil Chambers
