1980 Driver - small bumpers
(In Topic #237165)
Advice/help required regards my series 1 Driver.
It has the standard plastic bumpers with the normal hangar brackets.
I would to fit small metal black bumpers but it doesn't seem as if they're compatible with the standard bumpers which are fitted.
Does
Anyone know
If it is possible, and if so what is required in terms of parts and fitting.
If it's too complicated I will probably stay with as is.
Regards
Leembo
once you bolt the bumper parts together they just use the same four bolts to mount as your plastic bumpers in the same places.
Last edit: by mk1collector
82 golf cabrio (long term project)
83 golf driver (now a gti)
87 mk1 caddy
2004 landrover defender
2014 landrover defender
87 mk1 caddy
I just need to weld up the redundant bumper clip holes now
87 mk1 caddy
87 mk1 caddy
mk1collector said
You'll need bumpers, brackets, bracket bolts/nuts and end caps. Also the long centre rubber inserts if you want but these aren't necessary to fit the bumpers.
So basically a straight swap?
87 mk1 caddy
87 mk1 caddy
mk1collector said
If you have all the bits for the small bumpers then yes a straight swap
Thanks for your help mate
87 mk1 caddy
87 mk1 caddy
