1.8 Clipper struggling to start from cold
(In Topic #215184)
i have just had the head rebuilt and a weber carb conversion
the car still struggles to start from cold, seems like it's running on 3 cylinders, when there is a little bit of heat in the engine number 4 kicks in and runs as normal
when the engine is warm it will fire up virtually straight away on the button
its also had new dizzy cap, rotor arm, leads and plugs too
someone please help
regards
Has the problem started since having the engine in bits or Webber fitted?
the only thing I haven't changed is the dizzy, point and condenser
If you still have points have you checked the gap and looked for any pitting?
How old are your points and condenser and do you have a dwell meter to check the gap or feeler gauges?
Did you fit a new rotor arm?
In my 1978 Mk1 Scirocco I used to change my points and condenser ever year as the quality of new parts seemed to go down hill, I've since changed mine to electronic ignition with a Accuspark kit, best £25 I've spent.
I don’t think the stuff above will help with the cold start and rough running when cold but it will help with performance, petrol consumption and reliability.
Did you get the Webber set up when fitted and was it new?
havent looked at the points or condenser yet
where did you get a accuspark for £25 ?
ive got to get it back to the garage so they can look at a oil leak so will get them to check it all out
then eventually it will be set up on a rolling road to iron out the rough running just lack of funds at the mo is restricting me
No need to a rolling road set up, local friendly garage which does MOT will have a CO meter to set up the carb, there is a mixture screw on the side and a idle speed to adjust that's all you can do unless you take the carb apart and change over the jets in the carb.
