1.8 16v KR into Mk1 GX fuel parts needed
(In Topic #224500)
Discussion on fuel pump setup for a Mk1 GX receiving a 1.8 16V KR
I've been search the forums and seen a few posts about people engine swapping the 1.8 16v Kr engines into the Mk1. Ive recently bought a Kr from a mk2 Gti that I'm rebuilding slowly.
My next headache point is what do re fuelling…
I originally thought just buy/salvage the fuel system from a mk2 Gti but I read somewhere the lifter pump won't fit my current tank..
Just wondering if anyone has any ideas on what I can setup/ use for a fuelling this engine in a Mk1.
This is the first engine swap and rebuild I've done and I'm loving the learning process so please be kind, we all start somewhere.
* Fuel tank, accumulator, fuel pump, fuel pump cradle, brackets on the car, fuel pump relay and its wiring, fuel lines front-rear. I think you could reuse your fuel filler neck, breather hoses, tank level gauge sender unit (if you block up its fuel lines)
Will look into getting those bits! Cheers
