1.6 EG oversized cast pistons/ GE trans gear ratios-
(In Topic #216326)
Looking for info
Hello,
I'm in the process of restoring my 78 series 1 GTi.
Does anyone have a set of good/ used or NOS oversized cast pistons for the 1.6 EG??
Also, what are the gear ratios for the original GE code 4-speed trans?? I've looked at several gear ratio charts and searched with no luck…
Any help is greatly appreciated!!
Thanks,
Chris
Thanks,
Chris
There's a guy selling new cast oversize eg pistons in Austria on German Ebay. They are Hungarian pistons but seemed to be the only ones available. I've just bought a set and my mate is currently having some put into his block at the engine builders so have yet to have any feed back.
https://www.ebay.co.uk/itm/112785891572?ViewItem=&item=112785891572
or search on german ebay
4 x Kolben vollständig (übergröße) ø 80 mm Vw Golf 1 GTI 1.6 EG Jetta Scirocco
No table seems to list the GE code. My mates 4 speed is a GE so I know they exist.
1st is the same as all 020 boxes I imagine. Maybe you could look in the parts book and that list the number of teeth and work it out from there?
I think GE code maybe the same as GC but not 100%
Wow!
Thanks so much for the info guys!!! That is an excellent lead for pistons!!!!
As for the gearbox, I have been researching.. for now, I have figured out that the GE box has a 3.70 final drive, and the GC is 3.89 ( I believe )
I will post more as soon as I learn. It may come down to counting teeth, so I will do that if need be. My gearbox is now broken apart..
If anyone else has any info, it would be greatly appreciated!!-
Further research of the GE transmission gives me the following information:
GE 4-speed final drive / ratios-
Final drive - teeth- 74:20 = 3.70 *specific to GE code*
1st gear - 38:11 = 3.54
2nd gear - 35:18 = 1.94
3rd gear - 36:28 = 1.29
4th gear - 31:32 = .969 *specific to GE code*
The eBay seller mentioned above is out of stock on the O/S pistons. If anyone else has a lead, please let me know-
Chris
Chris
Chris
Thats hard luck on the pistons because he's sold a few sets over the last months. It was the only lead we found.
