02a in mk1 golf
(In Topic #217743)
Hi people as title says I know I need 100mm inner cv cups but which drive shafts do I use ?
Any help much appreciated
Nobody ?
Roach said
Thanks buddy
I have a pair of corrado drive shafts and a set of mk3 tdi shafts does anybody know if in can use them rather than paying out for a new set
Think you will find they are too long, wider cars than the mk1, could cut and shorten them if you have the required equipment
The other issue is that if your original shafts were 90mm, then you will need to change the spindles out to use the 100mm axles. The 100mm spindles can go either way, but the 90mm spindles can only use 90mm.
Ok got it thanks for the help guys
