‘92 Mk1 Cabby - Performance issues
(In Topic #234076)
I posted somewhere here already just I think it was the wrong place.
To get things started, I just bought my first Mk1 Golf 1.8 Carb. Having performance issues and from what I have read, it could be a number of issues. Please have a look at my engine photo and let me know what you think. Lots of work already as it’s pretty messy in there.
Thanks!
Rough idle
Stalls and cuts out
Fuel seems to be getting starved
After stalling it takes a number of attempts to start, sometimes doesn’t start back again until I leave it sitting for 10 mins.
The rubber engine mount is also broken which may explain why the flange broke. I need to figure out how to remove the choke and accelerator cable in order to lift out the carburettor. Thank you so much for the help!
Would you also have any suggestions for a upgraded carburettor or is there any need?
I have ordered a new flange hopefully that will help.
I'd give it a good service and check fuel, vacuum and electrical connections and run it so that each and every problem shows itself and can be fixed.
Why are you trying to remove it?Mk1-newbieee said
I’m trying to remove this cable but it just completely twists when unscrewing the bolt. Any suggestions?
It looks like the speedo cable, (I'm not that well up on autoboxes). If the same as manual GBs its clamped in by the plate to the right/underneath the ali nut on your pic. EDIT: also if like manual boxes if you yank at it the plastic cog on the end falls off into the bowels of the gearbox.
Loosen the Phillips on the cover plate that holds the speedo cable to the transmission.
Pull the whole kitten-and-caboodle out of the tranny by wiggling the cable left and right a wee bit as you pull op on it. You then may be able to hold the speedo gear with one hand and loosen the nut off the speedo gear assembly.
2.
If your cable is froze to the nut, just keep on loosening the nut till it is off….let the cable spin on itself it will be a pita and tighten up on you just keep the nut or cable tight while you reposition your wrench
If the cable becomes too stiff, then you remove the Drivers side Side vent, and carefully worm your arm to the rear of the speedo and "pop" the cable off the speedo. From under the bonnet you spray wd-40 or the like on the Grommet for the speedo cable through the firewall so the cable can spin.
Last edit: by Briano1234
The carburettor is now off and attempting to remove the tattered flange.
Should I check for anything else while the carb is out? This is exciting stuff guys!!
Please help.
What, if anything, is still attached to the inlet manifold?
Nothing left on manifold. (
The rubbers totally come away from the manifold side so buried in the rubber thats still attached to the carb should be 3 (or 4?) metal furrules that the carb fixing bolts screw into. Have a dig around with a screwdriver in to the rubber?
EDIT: this looks like yours but with the rubber still on the metal mount/manifold. Your fixings should match those you can see exposed?
https://www.youtube.com/watch?v=VfXz0E_cAdU
Thanks for your help btw
https://www.youtube.com/watch?v=sL7Nk8LiG2A
My only issue now is I’m unable to remove the bracket for the accelerator? See photo as I’m not sure if it’s the accelerator bracket.
https://youtu.be/sL7Nk8LiG2A
I used it to do my conversion, very helpful. The are 4 bolts holding the flange to the carb, anyway the vid steps you through it all.
but be careful as it will ping off never to be found again if you're not.
