Were VDO gauges(volt, oil etc..)available for the Campaign??
(In Topic #85010)
See you at the shows!!
Life Member
I'm not sure where they came from but the car is ex-BRM so maybe it inheited them at the same time as it's engine was upgraded.
If the needle is white and the oil pressure goes to 10 bar, its most likely a dealer-fit option or a good replication. If the needles are red and goes to 5 bar, its probably from an Audi. There are many 5 bar gauges on eBay (from Audis) but a handful of 10 bar ones. You need the correct sender to go with the gauge - which is probably why the MFA went inop.
i have the red needle 5 bar ones, and think they are genuine. :dontknow:
where did you get that info from paul?
I want the car to stay totally standard (I dont mind factory options), you know VAG/OE stuff!! :wink:
Dale
8Valverpaul said
I have the VW set of gauges then, just wondering wether to fit them or not now?? :dontknow:
Are dealer-fit options okay, or just factory-fitted options? I got my info from this site, many moons ago, can't remember the exact thread etc. I mistakenly fitted mine, thinking they were standard equipment, because they were in the pictures in the brochure, or something.
As long as you could drive away from the dealership with them fitted (when the car was new) then i'm happy!! I dont want to fit something that could'nt of been fitted to my Campaign originally!! :wink:
Life Member
If they did not come as standard on this model why didn't VW just block up the holes or make better use of the space?
Black Cabbie
Maybe its E-bay RARE?? :wink:
Right hand hole = Oil pressure / oil temp
Middle hole = Clock
Left hole = Voltmeter
Can;t see which cars these apply to but are all under Golf for 1983 year.
(Screen is too small to see the remarks column ops: )
8Valverpaul said
I have an untouched blank plate!!
It might be one of those really *R*A*R*E* L@@K!!!! bits 8)
vagcat.com lists the guages and has diagrams of the centre console with the housings, is it wrong? :dontknow:
http://www.vagcat.com/…t/vw/GO/1983/7/57/120553/
PS. you might have to register to see it but it's cool cos you can see loads of exploded diagrams for all sorts of bits 8)
Yradave says relax.
07792646786
07792646786
