URGENT - Need help please
(In Topic #107443)
I'm having to drive my 1800 Clipper about 350 miles tomorrow and having just given it a quick once over before hand, I've just noticed that the dip stick is cracked so that it does not create a seal. I'm guessing it's letting a bit of air in/out.
If I drive the car tomorrow with it like this will it be ok, or should I try and manufacture a seal somehow?
Appreciate a quick answer to this if possible….
DB
DB
if its the top bit that sits against the tube that dip stick goes in (the plastic bit) then wont gaffa tape do for the time being ?
obviously dont use it if its on the bit that goes into the tube to the engine
jimmy
jimmy
Ratty 83' 1100 Golf Now With 5 Speedsssssssss (Holly)
93' Polo Coupe ! .. Mates Project Car (Poppy)
70' Beach Buggy - Holier Than A Church !!! (Lilly)
72' Beetle in a thousand pieces (bro's) (Daisy)
The dip stick itself won't clip securely into the "..receiver..". I can fashion something for now with tape, but I just want to know what damage I'm doing to the engine if it is or becomes loose?
Thanks for the quick response!
DB
DB
personally i would just gaffa tape it really secure so it cant come loose then get a new one when possible
Gaffa it for now but swing by VAG and pick one up asap.
T
T
Will the fact that it's loose mean that air gets in and it damages the engine?
Have Gaffa taped it as best I can but it's not ideal!
cant see why it should ??
never given it thought before as air is in the top of the pipe and in the engine anyway
wouldnt have thought it mattered but dont know for certain
Cheers guys, reassuring that it's not something MAJOR to worry about anyway! I've taped it up as best I can and will pick up a new one when I can.
Thanks again…helpful as ever!
DB
DB
DB
Try Cq's he'll proabbly have one and post it out to you
link to the left…..
Dont forget to join up to the site as well!! its only ?15 for the year and loads of benefits too
you mean that orange bit of plastic is broken, they ALWAYS snap in 2.
if you are that worried about it, you can
1)find a piece of pipe to slide over the 2 broken bits and jubilee clip at the top and bottom.
2)gaffa tape aruond it at least 3 times round. and then jubilee clip the top and bottom of the tape.
should be fine tho tbh.
Life Member
I wouldn't panic unless you are losing oil through it and i doubt you will.
mines been lose for ages I never lose oil there and as for air getting in not a problem as long as its not water or sand getting in etc you will be OK im sure.
