understeer explanation please
(In Topic #80717)
what causes it, what camber adjustments, toe in/out ,can u make, to reduce it or increase it,
that sort of thing.
ive noticed it today, now ive got me 195 45 15s on :wink: , i quite like it, but need to understand it more.
cheers peeps
rebuild in progress....
Not very good description - I think increasing negative camber can help as under hard cornering you'll have more tyre in contact with the road and therefore more grip.
Guest user
it was rainin today, that was why i noticed it, i was givin it a bit ,now its workin, and i put my k&n filter in (chz storm!),
i had an open corner and floored it round in third, about 70ish, then it understeered, not suprisin really
when i changed the springs, i set up the camber meself for the old tyres (70s)today was the first day ive had the wheels on proper, and it was rainin,
2mo ill know if its doin it generally, i doubt it will tbh
having spent this lot im gonna save for the suspension replacement,
then its goin to falmouth tyres, :wink: i know the one you mean, thats where it was set up last time
cant believe the difference really from 70s to 45s,much better imo
thanks guys
so what dya think to me car then storm……
happy 60th by the way
Guest user
Guest user
change you driving style "scandanavian flick"
research that!
drive in go wide then back in sharp and then plant it and hopefully the back will step (if you are comitted :wink: ) ala no understeer 8)
if the sumps not dented its not low enough
standard origonal 82 mk1 jetta c for sale
i think its cos my suspensions too soft at the rear, thats soon to be sorted
:wink:
in the dry today and yesterday it didnt really happen, i do notice it when its wet tho
chz
jimbo16v said
ive tried alot to sort out understeer by numerous ways ,tyre pressures ,tyres roll bars etc etc and there is only one way to eliminate it
research that!
The scandanavian flick is only really appropriate for cars with a tendency to oversteer.
I am surprised that you couldn't sort out your understeer by progressively increasing spring rates and thicker anti-roll bars. Also, lower profile tyres will reduce understeer. If you really wanted to change the Golf to oversteer rather than understeer biased, you could fit lower profiles at the front, leave the rears as standard, then stiffen and roll bar it very hard. But you want a little understeer for stability, surely?
Ever heard of left foot braking? :mrgreen: :mrgreen: :mrgreen:
But yeah stiffening your rear setup would also help 8)
ps :mrgreen:
its no problem in the dry, but in the wet was a bit disconcerting!
