seat repairing - anyone tried it?
(In Topic #112429)
has anyone tried to repair there mk1 drivers seat?? and how did they get on?
Are there any companies that repair the seats? Would imaginre they are very expensive??
There must be some repair service cause a lot of people seem to have spanking new looking seats!
thanks, rowan.
have a couple of practice goes first tho (if you are going to do it yourself)
what patterns are you looking for?
i MAY be able to sort something out!
Life in the French Alps: <a href="Le Franco Phoney: All things French in La Clusaz, Annecy and Haute Savoie">www.lefrancophoney.com</a>
Spudfingers said
Anyone reproducing the gti cloth? I think they'd make a killing… seriously it's probably a big market if you expand to a few classic cars!!!
I thought this aswell mate, so i emailed the company that made the orriginal material for vw, benoke or something i think they were called.
They basically said that for them to remake an old cloth design they would need a minimum order quantity, which was something like 10000 euros worth.
So i sort of left it at that
now i know i can get it a lot lot cheaper than that. just need to know the material
LMAO :lmao: :lmao: … I'd walk away from that too
Maybe it'd be something we could get from one of our breakers here?
What are you thinking Dean? Can your company make them bud?
but i do have the right suppliers who could make the material
do i just get a knife and unpick the thread holding the drivers bolster on??
pretty scary - really dont want to mess up my seats but would love nw looking black bolster material on all seats :mrgreen:
can you explain a little more for me please?? :?
Tbh the worst part was stripping the original seats to get a template and then covering washing line to make piping.
If you can get the seat cover off the frame the pieces seperate quite easily with a stanley blade and some tweezers.
If you pin this bit to the new material and draw a stencil - all that is left is to cut out, put in the stitch lines and re-attach to original cover.
Hope this helps :dontknow:
i have the binding machines that do this for you.
or i can overlock thr non piped areas.
like you say, the stencil is the hard part,
I have labelled and kept the stencil tho just incase the car needs another make over
The worst bit there is getting the headrest mounts out which sink through the material into the metal work as they are barbed and awkward to get at.
I found the best way was to get some mains earth cable (5amp) and keep twisting the bare copper wire around the clip with a pair of long nosed pliers until all four barbs were touching each other, the headrest mountings then drop out quite easily. You can pop them back still with the wire on and then just snip the wire.
I stripped a passenger seat the same and had a trimmer remove the rear vinyl part of the drivers seat and attach it to front of the passenger seat as the handle which lets rear passengers in is opposite handed obviously.
The trimmer charged me a tenner for his trouble!
Just take plenty of pictures as there are a lot of clips and springs inside once you start stripping.
Life Member
11-12mm socket also does the job nicely :wink:
jai said
Wasnt lucky enough to locate the binding machine cos the hubby wanted it done in a weekend The results were really good tho, i just had to perfect the art of getting the stitching and material tight around the washing line (without breaking needle).
oi they need doing again your cat has scratched the passenger seat to death
