powering a welder with a generator?
(In Topic #120416)
just about to start stripping my mk1 to do the welding work required and i need to know if any1 on here has used a petrol generator to power a 100A+ welder, if so what type of generator did you use and what output did it have?
i'm renting a council garage so it's not near my house so no chance of rolling it down the street to do the work!!
cheers for any help given.
andy.
Life Member
think i'm just gonna have to see if i can get a loan of one to try it!
Andy.
VOTE FOR MY CAR ON COTM
92 clipper, chrysler red, tt interior, 16" splits, slammed!
Life Member
paul_c said
Just weld with gas. You'll need a bottle for MIG anyway, so why not get 2x bottles from a gas supplier and then all you need is the torch set, etc. Gas welding is a bit more versatile too. Problem solved.
keep a fire extinguisher handy
this info was taken from this post on the second page.
What size generator | MIG Welding Forum
Hi,
To work out the genny size it is
Open circuit voltage X Amps + 10% = KVA Generator
e.g.
130amp sip mig has an open circuit voltage of 18 - 34
130 x 34 + 10% = 4.86KVA
goin off this info my clarke pro90 welder would need a 2.57KVA Genny
open circuit voltage is 18-26 and its a 90 amp welder
90 X 26 + 10% = 2.57KVA
hope this helps others too.
andy.
welding
but if your a good enough welder you can get away with mig just use a scrap piece of metal to get the corrrect wire speed and amps before you start welding the body.
usually you want a smooth sounding flow of like a crackle with mig.
have you chosen how to do it yet?
golfs are fun golfs are fast ive just seen one go past
cheers for the advice though.
andy
For someone who wants to do big things (Rear pannel) with not much know how…
aha.
MIG welding is what probs 80 odd % of people use to dp repair work on there cars, it's easier to learn how to do it, all you need to look for is the sound of bacon frying in the pan! sounds daft but when you try it you'll see what i mean!
hth.
andy.
Its more i dont know whether its too big a job for me to do, ive welded a few times but never anyhting that had to be precise.
Il have a go, see what happens, sjut want to know im getting the right equipment enit..
tah.
