Possible daily driver - Reliability concerns
(In Topic #87191)
I have the oppertunity to purchase a pretty mint '82 1600 gti with 140,000 on the clock. Its recently had a respray, new clutch, new starter motor, full suspension kit and other small parts replaced. The engine sounds very smooth and it drives nicely. I love the car and i am desperate to buy it, as ive wanted a mk1 since I was about 10!
The only thing holding me back from buying the car is reliability concerns as it would be my daily driver. I need it to get to and from work and a fortnightly 3 hour round trip i have to take. I am worried that i am being unrealistic when expecting a car of that age to be as reliable as i need it to be. I am happy to do running repairs on it myself, from a Haynes manual etc, but dont want to be sat on the side of the road waiting for the AA everyother day!
Problems where the car still runs that u can fix at the weekend are part of the fun for me, I just cant afford for the thing to be blowing up all the time!
Do many of you guys use your mk1s day in, day out and use for frequent long journeys? Do you experience many serious issues that leave u stranded?
Cheers! Andr
It's been very reliable on the whole! (touch wood)
1983 Lhasa Green GTI
<img>
mk1 1.1 C
It's worth spending some time adjusting the fuel mixture screw (recessed 3mm allen head bolt just next to the metering head) to get it just right, as a small adjustment there can have a large effect on the overall fuel consumption.
Overall they're very reliable cars as long as you look after them, so I'd have said you'd be fine…
Rich
People i work with often comment that they think I spend a fortune on spares, but never stop to think how much their car loan costs EACH MONTH! Not to mention service costs in a garage for a newish car. Running an old car is far cheaper….
re mixture setting, this works
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=21786
rebuild in progress....
1. Warm engine through and leave it idling
2. Ensure timing is set accurately (you'll need a timing gun for this, or a good ear if you know what you're doing)
3. Using a long 3mm allen key, rotate mixture screw anticlockwise (leaning off mixture) until the engine starts to struggle to idle
4. Mark this point / remember it
5. Rotate allen key clockwise (richening) until engine starts to struggle to idle again.
6. Mark this point
7. Optimum performance is midway between the 2 marks
8. Optimum economy is just lean of this point.
9. Using 7mm spanner, adjust idle screw on the back of the throttle body to give you around 1000rpm at idle.
Once you've adjusted the mixture screw you'll see how sensitive it is.
HTH
Rich
