Mk2 golf
(In Topic #87346)
Mk2 golf
he said the engine runs fine aswell as the gearbox
Bog standard 1300 Driver!
thankyou
Engine seals should be ok. But if i was you when changing the oil i wouldnt have an engine flush due valve guide seals and things being old and worn. The engine flush may balls them up.
rebuild in progress....
buy the mk2 but dont pay more than 100 maybe 2 if its reasonable
Also - if its a GTI, what about insurance?
Also consider that no matter how much time, effort and money you've spent on it, its still a Mk2 which has been worked on rather than an original and well maintained one, Mk2s will always be more commonplace than Mk1s and this is reflected in their values.
paul_c said
Do you have space to store it off the road? And to work on it? Do you have enough money to buy tools and parts for DIY tasks, when it goes wrong? If not, it will end in tears…… If you have enough enthusiasm, then taking things steady, searching the forum(s) for advice (you will probably find the issues you come across, are known issues, they are a popular DIY car), and if you're stuck, posing a sensible question on the right forum, will see you through. Be prepared to give over some tasks to professionals, though. For example, some bushes need to be pressed in and out, so you'd need to give this to a garage to do, etc.
i got space for it, i got the time to do so. not sure about money i got alot of tools here and i know people who would have some that i can borrow. i've also checked insurance and its alright, its a mk2 driver 1.6
mvdevelopments said
buy it and drop it down to me i'll have a look over it :wink: ive got one
where abouts do you live?
shepreth cambs check www.mvdevelopments.co.uk for map and numbers :wink: doing a couple of peoples cars on here at mo hope they will vouch for me
the last mk2 i got was a driver, for a 100 it looked a mess, but after a bit of bodywork and paint restoring, a good hoover and service i got back 500
its a good way of learning about mechanicing too
good luck
Rust isn't c##p, it's lighter than carbon fibre
