Mk1 Cabriolet
(In Topic #72165)
Mk1 Cabriolet
Do we have any Cabriolet owners out there ? Mines a K reg blue clipper which I love to bits except I'm always on the lookout for a mint Rivage…
Anyway does any one know why my 1800 carb clipper might be running on ?
Cheers, Jez
Cheers, Jez
Work on my Clipper
Life Member
Definitely other cabriolet owners about, we're trying to encourage them! :wink:
As for running on. you'll probably find that your wax stat fast idle valve is knackered on your Clipper. Does it have an overly high idle when cold? (Say up to about 2000rpm)
Cheers,
Drew.
Cheers,
Drew.
Once a Mk1 fan, always a Mk1 Fan...
I'm another Cabrio owner. Mine is a '88 F reg GTI with big bumpers. It just hit 140k yesterday! Its the car I use as my main car so its no where near mint but still fairly tidy. I'd like to get a nice Sportline but I'd only get one if I stopped doing the miles I do. Its a bit of a shame I'm putting so many on my current cabrio but they are made to be driven and I'm having fun doing just that!
Ross
Ross
Ross said
……. but they are made to be driven and I'm having fun doing just that!
Ross
….and so are we….
Two more here.
vwgolfmk1.co.uk
Here's mine!
Life Member
You should upload that photo to the image database! Nice pic.
Cheers,
Drew.
Cheers,
Drew.
Drop top
Thanks for the reply about the wax stat Drew… Do you know where I might be able to purchase a replacement wax stat? I've been into G&S in Hitchin and they did not have a clue….. they tried to sell me a whole new Webber carb !
Also do you know if the haynes manual for the mk1 golf talks about it?
Are there are any Rivage owners out there? Blue or green?
Cheers, Jez
Cheers, Jez
Work on my Clipper
Rivage wheels
Just thought I'd mention it there are some 15" rivage wheels for sale on www.loot.com ?250 bargin !!
I bought a set for my clipper a year ago and I think it makes the car.
Work on my Clipper
Mk1 Cabrios
Hi, nice site!
I've got a 1990 J plate Blue Rivage, low mileage and absolutely original. Every bit of paper since it was new and it looks the business.
Where is the register information on here? I understand there was originally 260 Riv's & Sportlines made in total. I know of three that are still around.
Sorry can't get the link up but there is a mint Rivage on Ebay at moment - under Automotive (naturally) VW Golf MK1.
It looks perfic, presently at ?3.5K
Have a look
Have a look
1984 Black GTi Cabriolet here, currently SORN'd but hope to be able to spend a bit of money on her over the winter to get her back on the road for the summer.
Just out of interest what order do you think a respray and a new hood should be done i.e which one would make more sense to have done first as can't afford them together?!
Cheers Andy
Cheers Andy
It depends whether the car is under cover over winter. If not a new hood maybe more urgent.
Otherwise it would make sense spraying it first, as you will have to remove the new cover again when you have it sprayed. You never know it could get damaged. Then at least you could put your nice new cover onto your newly painted car which will set if off then. Otherwise you will be fitting, removing and refitting your new hood. Best just put on once me thinks.
By the way there is a german site on ebay which is selling mohair hoods for ?350 delivered. Seems OK to me as I have a clipper which needs a new hood.
Cheers Andy
Which comes first - the chicken or the egg??
How bad is the hood? AND how bd is the rear window frame?
See Hood Saga
If it's bad replace it first, bearing in mind that it will have to be taken off for the respray (the only awkward bit is removing the rear tension cable and REPLACING it).
But that again depends on how badly the car requires a respray !!!!!
Decisions, decisions……
hmmm it is a tough desicion, the hood seemed fine but when the recent snow was thawing I noticed it dripping through a slight tear above the drivers door, just bought a breathably cover for it so hopefully I can save my pennys over the winter and get a new hood/respray in the spring.
Prowler I checked my rear frame a while ago when I first saw your site and looks pretty rusty to me so looks like I'll need a new one when I come to replace it .
Does anyone know of any specialists in the Herts/Beds/ N London area??
hi
i have a 1989 clipper in silver . i love the car but my breaks are not as good as they could be(i think) . i went to the garage and had them check out and they said they are fine :?:
is it just mine or are they all this bad a stopping,anyone know of anthing i can do without too many mods?
ps anyone know where i can get some nice wheels that will look good on the car as the last owner put some boy racer wheels on her and i want a more original look
ryan,
Mk1's have a bad reputation for brakes which I think is largly unfounded. The main cause of bad brakes is wear and adjustment. The original RHD road tests did not mark the brakes as bad!
Make sure the rear drums are adjusted correctly and that the rear cylinders are not leaking.
Make sure the rear compensator is working and adjusted correctly.
Check for excessive wear on front disks.
Check for play in the pedal to servo linkeage and repair as necessary.
Also check that something silly hasn't been done at the front (one of mine had a large disk conversion with standard disks fitted so that the pads were only 50% acting on the disk!)
Obviously change pads and shoes as required.
cheers i will check that out.
their something i am not sure about:
i have a 1989 clipper, is it a true mk1 golf or just the style of the mk1 golf
ie. does it have a mk1 engine,breaks ect
or does it have mk2 engine,breaks ect
plz could someone help me wilth this as i would like to know as much about my car a poss
