Mk1 Cabriolet
(In Topic #72165)
Mk1 Cabriolet
Anyway does any one know why my 1800 carb clipper might be running on ?
Cheers, Jez
Work on my Clipper
Life Member
As for running on. you'll probably find that your wax stat fast idle valve is knackered on your Clipper. Does it have an overly high idle when cold? (Say up to about 2000rpm)
Cheers,
Drew.
Once a Mk1 fan, always a Mk1 Fan...
Ross
Ross said
……. but they are made to be driven and I'm having fun doing just that!
Ross
….and so are we….
Two more here.
vwgolfmk1.co.uk
Life Member
Cheers,
Drew.
Drop top
Also do you know if the haynes manual for the mk1 golf talks about it?
Are there are any Rivage owners out there? Blue or green?
Cheers, Jez
Work on my Clipper
Rivage wheels
I bought a set for my clipper a year ago and I think it makes the car.
Work on my Clipper
Mk1 Cabrios
I've got a 1990 J plate Blue Rivage, low mileage and absolutely original. Every bit of paper since it was new and it looks the business.
Where is the register information on here? I understand there was originally 260 Riv's & Sportlines made in total. I know of three that are still around.
It looks perfic, presently at ?3.5K
Have a look
Just out of interest what order do you think a respray and a new hood should be done i.e which one would make more sense to have done first as can't afford them together?!
Cheers Andy
Otherwise it would make sense spraying it first, as you will have to remove the new cover again when you have it sprayed. You never know it could get damaged. Then at least you could put your nice new cover onto your newly painted car which will set if off then. Otherwise you will be fitting, removing and refitting your new hood. Best just put on once me thinks.
By the way there is a german site on ebay which is selling mohair hoods for ?350 delivered. Seems OK to me as I have a clipper which needs a new hood.
Cheers Andy
Which comes first - the chicken or the egg??
How bad is the hood? AND how bd is the rear window frame?
See Hood Saga
If it's bad replace it first, bearing in mind that it will have to be taken off for the respray (the only awkward bit is removing the rear tension cable and REPLACING it).
But that again depends on how badly the car requires a respray !!!!!
Decisions, decisions……
Prowler I checked my rear frame a while ago when I first saw your site and looks pretty rusty to me so looks like I'll need a new one when I come to replace it .
Does anyone know of any specialists in the Herts/Beds/ N London area??
i have a 1989 clipper in silver . i love the car but my breaks are not as good as they could be(i think) . i went to the garage and had them check out and they said they are fine :?:
is it just mine or are they all this bad a stopping,anyone know of anthing i can do without too many mods?
ps anyone know where i can get some nice wheels that will look good on the car as the last owner put some boy racer wheels on her and i want a more original look
Mk1's have a bad reputation for brakes which I think is largly unfounded. The main cause of bad brakes is wear and adjustment. The original RHD road tests did not mark the brakes as bad!
Make sure the rear drums are adjusted correctly and that the rear cylinders are not leaking.
Make sure the rear compensator is working and adjusted correctly.
Check for excessive wear on front disks.
Check for play in the pedal to servo linkeage and repair as necessary.
Also check that something silly hasn't been done at the front (one of mine had a large disk conversion with standard disks fitted so that the pads were only 50% acting on the disk!)
Obviously change pads and shoes as required.
their something i am not sure about:
i have a 1989 clipper, is it a true mk1 golf or just the style of the mk1 golf
ie. does it have a mk1 engine,breaks ect
or does it have mk2 engine,breaks ect
plz could someone help me wilth this as i would like to know as much about my car a poss
