matt lacquering rust... pics please :)
(In Topic #127281)
ANYWAY…
anyone got any pics on mat lacquered rust???
booze and boredom, the greatest mix
This is not a good town for psychedelic drugs
ill do one one day
Ill do you a ratt cab if you want? have enough suspect parts for a rat look one.
it was mint really, a little suspect..
(vin screwed on and log book in someone else's name)
but it had had a hit in the front and new panel fitted. apart from that it was solid lol.
i want one now!
paul_c said
I'm confused - paint doesn't stick to rust. Whenever you do "normal" bodywork, you wire brush or grind down the rusty areas, then if needs be use a skim of filler to flatten it, then apply primer, then top coat(s) of paint. AFAIK clearcoat or lacquer is the same as paint, just clear. So, what's the magic going on here?
gotta bend the rules a bit, it doesnt stick to the extent that if you started picking it would come straight off, but so long as you dont, and apply enough layers it stays on, again so long as your not brutal with it, i imagine over time it will start flaking, but its been laquered a month and it hasnt started to lift, alls well so far
