How low can you go?
(In Topic #81791)
How low can you go?
Please can you post:
lowering at front:
lowering at rear:
wheel size:
tyre size:
arch mods?:
any rubbing?:
I'll start it off with:
lowering at front: 80mm
lowering at rear: 80mm
wheel size: 13x5.5
tyre size: 175/70R13
arch mods?: no
any rubbing?: no
Thanks guys! Once there are a number of replies which provide a good spread of data, I'll collate some kind of reference table. If there's anything special done, for example if you have narrowed axles, running different top mounts or hubs, etc I am sure you will mention this too!
lowered at rear 110mm
wheel sixe 6x15 g60 steels
tyre size 165 50 15
arch mods fully rolled and smoothed to inner arches f + r
rubbing hmm not on arches! :roll:
but os drive shaft on the body through the chassis leg and it has been modified!
gear box mount on the floor at times ! (2" clearance)
sump isnt a problem as it is small block but just behind the front wishbone bolts where the lower chassis leg halfs are welded together , they touch sometimes !
hope this helps :wink:
if the sumps not dented its not low enough
standard origonal 82 mk1 jetta c for sale
got any pics of what these heights look like?
I'll have to go and measure mine, hopfully post them up in a bit….
black 5 door mk1 GTD
mk1 scirocco Gli in bits
1980 1600 GTI, daily driver.
lowering at rear: 40mm
wheel size: 15x7.5J
tyre size: 195/50 15
arch mods?: no
any rubbing?: no
My backbox is about 2.5" off the ground however, so i am effectively as low as i can go.. (could go another 22mm i suppose)
No idea what kit it is.
My Build Thread
procalx said
lowering at front: 40mm
40mm is nowhere near as low as you can go - Your exhaust has either been hung incorrectly or it is a rather large design!
My Build Thread
Mate its HUGE i could probably go for 60mm, but my wheels are 7.5J ET18 15"
lowered front driver. 60mm
lowered rear pass. raised 5mm apparently :doh: :roll:
lowered rear driver. 15mm
wheel size: 7x15" et 26
tyre size: 195/50/15
arch mods: fronts - lip cut from 10 - 2 ish and inner plastic trimmed to suit, rears basically nothing at the moment though I did slightly fold the lip in hasn't really done much though…
any rubbing: a touch on the rears with 2 or more people in the back over bumps
I've also scraped the crap out of my gti spoiler, and knocked one half of it off once already 8)
done on V-Maxx Coilovers hence the uneven numbers on each corner, this was pretty much how I first set them up I will go round and even them up at some point, but I plan to sort the rear arches first then lower if quite a bit more at the back, although I hope to have a new set of wider 14" wheels soon so will have to see how they fit….
