HELPP ME!
(In Topic #74694)
HELPP ME!
good luck
Corrado G60 - Black Leather Interior, BBS RKII Splits, R1 Charger, 65mm Pulley....
Unblock the breather or replace it….. check the oil level.
If there is engine wear you could get blowback.
A quick test is without a compression test is……on tick over remove the dip stick, put your hand over and check for excess chuffing.
Do the same with the rocker cover oil filler cap ( loosen and slowly lift up or there will be oil everywhere! )
