Help?
(In Topic #82657)
Help?
Im looking at possibly buying a Freg 1988 1.8 Clipper Convertible. went to look at it today and it looked in pretty good condition. Ive been wanting one for so long and have recently decided to sort it out =)
its done 111,000miles had a new roof fitted and from the information on the website fitted properly. its got a few bits of rust here and there mostly on the rear sils above the body kit which is heavy and pot rivited on engin has recently had some seals changed no visible leaks and was quite tidy. no smoke from the exaust and he is replacing the fan
The chap wants ?1800 whats your thoughts.
My alternative is to buy Gemmagti's very very nice black
so 18 Cab or 1.6 Gti for ?3500
Please Help
Sounds ok, but be careful of riveted on kits, could lead to bad under-kit rusting.
Have you checked the usual golf bits? Fuel filler neck, fusebox and all the electrics work ok?
Pricie
I wasnt sure really what to look for :?
the electrics I saw looked ok and all worked fine pluss no ones cut holes in the parcel shelf if thats still what its called
thanks for reply
the roof is looking really new, which means its been replaced recently.
depending on how the roof was b4 it was changed alot of water can get in to the filler neck area and rust it from the outside in, that would be my first and only concern really
heres the buying guide for ya, print it out and take it with you ,
every point you find is a few quid off!
i would aim at payin between 1300/1500
good luck
dave
rebuild in progress....
I would deff check for fusebox rot and fuel filler neck too.
Easy to do, Fusebox is passenger side, behind the glovebox (unless they moved it for the mk2 edition, mines a Y reg mk1 and thats where it is)
Fuel filler neck, just reach up under the rear arch an it should be in the top lefthand corner, give it a real grabbing and feel around, if it looks and feels strong, go for it i'd say!
But remember to haggle them abit!
Good Luck!!
Pricie
Web Team
Here's the link I think dave meant to post for the buying guide
http://www.vwgolfmk1.info/main/Buyingacab.pdf
Think Ill be going back and having another closer look :?
probably with ?1500 cash in my pocket see what we can do
then I can spend ?1800 on making it better I hope
If I were you and I had that much money to spend, I'd go for the tintop every time. Lighter, quicker, more fun to drive (1.6 .v. 1.8 ), rarer… Just better really
HTH
Rich
however,
i reckon if you spent 1800 on a good cab, youd get one quick mofo
thats great to pull in in the summer!!!!!
1.6GLi Cab!
Pricie = True old skool drop topper!
