HELP ME WITH THESE NEW WHEELS PLEASE
(In Topic #82608)
These are the wheels i got
http://www.motor-world.co.uk/images/hires/8661.jpg?PHPSESSID=c55d3cb729e872143b2fdbff2b6a103e
15inch with yok tyres, they were on a corsa for 4 days so they are brand new.
(?195 i payed)
i also got a full set of locking nuts and some sprigot rings.
Check the charts i found below and see if you agree with this.
THE SPIGOT RINGS I GOT ARE 56.6MM(VAUXHALL), CAN I RUB THEM DOWN ABIT ON THE INSIDE TO MAKE THEM 57.1 (VW) SO THEY FIT?
SAVING ?20 AND TIME…
DO I NEED SPACERS WITH THESE WHEELS?? DON'T UNDERSTAND THE OFFSET THINGY…I WANT THEM TO LOOK WIDE…
I DON'T KNOW IF SHE HAD SPACERS OR WHAT THE OFFSET OF THE WHEELS ARE NOW??
I FOUND THESE ON THE NET
VAUXHALL
Model P.C.D. Offset C/Bore
Corsa 4 x 100 42…45 56.5
VOLKSWAGEN
Golf 4 x 100 32…38 57.0
from here (http://www.carlsalter.com/wheel_fitments.html)
sprigot rings available on ebay are these
56.6mm Vauxhall / Daewoo
57.1mm VW / Skoda / Audi
ANY ADVICE WILL BE GREATFULLY ACCEPTED AND REPLYED TO.
CHEERS
LAZYBLUE
13th sept 2006
13th sept 2006
Reckon you might get a better response on a car modders site.
Good luck
muttley racing ftmfw
As far as filing down the centre bore, it would be better to mount it on a lathe and cut it down properly. I'd be tempted to re-lacquer the rear/bore of the wheel once you've done this, too.
The suspension is standard, the new tyre size is 195/50/15.
I have the 13" 9 spoke vw alloys on at the moment with 175 tyres on.
(they will be for sale once i get these 15's sorted out. They have 4 new tyres fitted, if anybody is interested….)
steven
13th sept 2006
As for the alloys, have a look on the wheel to see if you can spot the ET number. It will be either in the 30's or the 40's. Aftermarket alloys are often different ET's to standard anyway. If it's on the 30's - no problem, put them straight on. Something like 42 may cause the tyres to touch the struts at the front. Fit the wheels, lower the car to the ground and see if the tyres touch the struts. If they do you'll need thin spacers. An ET of 49 and you definitely will I reckon.
Good luck !
Mark
so with that offset you reckon, rub the spigot ring down till it fits then just put the wheels straight on with no spacers.
i'm starting to get some where here,lol
13th sept 2006
Cheers,
Mark
13th sept 2006
