HELP !! ENGINE PROBLEM 1.8 GTI :(
(In Topic #161696)
MY GOLF MK1 IS MISFIRING AND NOT IDLING PROPERLY
SIMULAR TO : http://www.youtube.com/watch?v=iJpWhgyTfc0
ANY onE HAD THIS ISSUE WANT TO FIX IT THIS WEEKEND ??
You don't say where you're located, what model of Golf, engine size etc or what you done or didn't do to cause it.
Plus the use of capitals is deemed shouting .. Ops
I HAVE MENTIONED THE ENGINE SIZE ON THE HEADING
ITS A 1.8 GTI CONVERTIBLE
LOCATED BERKSHIRE
ITS NOT SHOUTING ITS JUST A HABBIT
IT HAS BEEN STANDING FOR A FEW MONTHS I STARTED IT UP 2 WEEKS AGO AND IT WAS RUNNING ABSOLUTELY FINE I BOUGHT MY CAR BACK HOME YESTERDAY AND JUMP STARTED IT AND THIS HAPPENED AND ITS ALL I GET NOW HARD TO START AND MISSFIRING
LOCATED BERKSHIRE
As its been lying up, Try putting new fuel into it. Change the fuel filter. Change the plugs and fit a new cap & rotor.
It's still classed as shouting and now you've been advised is just bad manners to continue.
sorry if you think that i am shouting
i have changed the fuel filter the fuel was dirty
also i have put new fuel in
also i have changed the plugs
still is exactly the same also it has not been standing for too long as i have another mk1 which hasnt been started in 2 years and runs fine :s
Ok you've made a good start in what you've done, this eliminates some of the 'basics'. I still think it's a fuelling issue but can't physically help out as I'm located hundreds of miles away from you!
Have a look in the forum for the injector testing - may be a sticky post? And try this, it involves using jam jars etc but will eliminate any issue you may have with a sticky injector, fuel pressure etc. let us know how you get on.
I HAVE HAD SOMEONE LOOK AT MY CAR I HAVE FOUD OUT THAT MY MANIFOLD IS LEAKING BADLY DO YOU THINK THIS COULD BE A PROBLEM WITH IT AS I AM GOING TO GET IT FIXED COULD THIS BE A PROBLEM AS THE PERSON SAID MY CAR WAS NOT MISSING :s
If you've has someone physically look at the engine, I'd go with their diagnosis rather than relying on the forum to give a better 2nd opinion. He (she)'s had the opportunity to see it, run the engine, hear it, look at components, rev it up etc etc
A leaking manifold is an issue which needs to be corrected, to get an engine working properly.
