Has ANybody Welded USING!!!!.....
(In Topic #75324)
is this a good method?? if ur on a budget and dont have the faciclites or is it beetter to just get mesh and some fibergalss or filler with metal shavings in?
Birmingham
c11rgd - why dont you tell us exactly what you need to repair and we can maybe then help on best options for you?
welder
Birmingham
You want to get a nice Turbo MIG - dead easy, cheap and effective. Other options are ARC (stick welder) but they are usually far too heavy duty for car body work, Oxy Acetaline but that needs big bottle athough you can weld rust with it or TIG but that is simply far too expensive.
DO NOT BUY A GASSLESS MIG - they are little better than useless. Get a decent Gas one and use CO2 Argon mix. Most car body work you'll be using .6 wire with. You could do worse than a look in machine mart - the Clarke ones are pretty good and not too much money either.
Best of luck,
Steve
I think half the skill in mig welding is getting used to your equipment and knowing how to set up the power/feed rate….. the rest is technique.
w
i dont want to be buying something imonly gonna use once u know wat i mean?
so really something simple i guess!
Birmingham
Mig welding!
Regarding buying a MIG welder for not much use, I'd 100% recommend you do, because if you can weld it opens up a world of opportunity for getting cars back on the road which would otherwise be scrapped. Also, if you spread the word about that you're a welder, I am sure over time enough people will put work your way for the little welding jobs that older cars sometimes need to get through an MoT.
I learnt to weld in work a couple of years ago, and did all the welding on me car, saved a hell of a lot money, and you can look back at your own work. :wink:
d
its just that u know when u need something u need it bad, and i know once the cars done and ive moved on, its just gonna be sitting there or on ebay after a while until the next time i need one, would rather put some of that money towards the car or somehting!
neways thanx
any one recommend a basic model or starter model or something!
Birmingham
The Clarke welders aren't too bad, SIP always used to get good reviews in the classic mags. B&Q sell one (online only?) called 'Cosmo' (From memory) which I'm told is just a re-badged SIP unit.
1983 1100 C
1983 1100 C
d
Birmingham
