Hard or soft?
(In Topic #72783)
Hard or soft?
mk1 silver campaign totally standard lowered on coilovers magic tree vanilla
Just had a full outer body restore
Guest user
Been meaning to ask the same question - if anyone has gone from modified to standard and been happy with the change. Just worried I'll lose some of the grin factor!
The good points are:-
1. It feels like I've got powered steering
2. Its really comfortable
3. No more slowing down when you see a matchstick or anything larger than that in the road
4. No more cringing when the suspension bottoms out over a bump
5. It does feel like you've been to the gym for a work out after you have been driving round town for 20mins
5. Plus its still lowered by 20mm so it doesn't look high.
No the bad points:-
1. It feels really weird like the front wheels are loose
2. The steering wheel turns at any camber in the road, you have to adjust the steering wheel all the time while your driving
3. You tend too understeer more goin into corners
4. Wife can drive it now the steering not heavy (it is insured in her name)
I'm not sure yet if Its lost the grin factor as I haven't drivin enough miles to see which ones best
I've had both my cars set up for fast road driving by a company in Norwich called AUTOTEST, they have set up the caster, camber, toe in/out. On my Scooby and the GTI
This setup is amazing and worth every penny I was surprise the amount of understeer they have taken away from BOTH cars, they no longer follow bumps in the road and theres no need to constantly fidget with the steering wheel.
Especially the golf as its so light it now stay very flat around tight turns under thottle and will only understeer if you get a bit carried away.
For about ?50 this is a top mod and will not cause any addtional stress or wear on the suspension, wheels or tyres.
