Electricians advise New Oven : )
(In Topic #143842)
Theres a terminal for Neutral and live but the Earth looks like it screws to the Plate….
But didnt want to just go straight ahead and do this incase I bugger it up.
Also Is plug and socket with a nice thick bit of wire ok (as thats what the last one had for 15 years)
Cheers for any advice guys
heres the terminal plate bit
<a><img></a>
Normally single ovens are low kw but doubles will need a big cable.
<a><img></a>
earth earth earth, the word means nothing to me now :?
<a><img></a>
Also you should be able to locally isolate the oven without moving the oven or by
switching off by the main fuse, for easyness and not having
switched spurs or 20amp double pole switches above work top level (for isolation purposes only) I tend to put them in the unit next to the oven.
All appliances in the kitchen should have accessible points of isolation, fridge, extractor hood, washing machines and so on.
spence
<a><img></a>
If it was me I would see if I could put the socket in the unit just in case you ever did need to switch it off after your missis sets fire to the Sunday roast haha
Spence
