cheap coilovers ?43 with delivery from america
(In Topic #100099)
money is an object at the moment
does anybody know if these coilovers will fit or how easy it is to adapt these to fit a mk1 1992 gti cabrio.
they say they fit all golf and jetta gti from 1985 to 2000 but say they dont THINK theyll fit a 92 mk1 cabrio.
heres the link
http://cgi.ebay.com/ebaymotors/Scale-85-00-GOLF-JETTA-GTi-LOWERING-COILOVERS-SPRING_W0QQitemZ170235168067QQcmdZViewItem?hash=item170235168067&_trksid=p3286.m14.l1318
i need new shocks on the rear anyway(?12ish from gsf) so if needed i could get none standard.
i know they say you get what you pay for but i want something cheap to put me on, and im not racing her.
thanks for any feed back
Joe
Joe
Black 1992 gti cabrio sportline
this was his reply
"personally i wish a hadent bought them lol they were a pig 2 get 2 fit right didnt really go as low as i thought …about 1cm above the tyre ..i would expect coilovers 2 go lower really ..still make a clunking on the rear aswell …wish i had just bought shocks and springs ..hope ive helped very hard ride"
so looks like ill be saving up
janspeed keep advertising a set on ebay for about ?240 with postage, does anybody know if there any good or have any suggestions.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=180260568333&ssPageName=STRK:MEWA:IT&ih=008
thanks Joe
Joe
search mk1 coilovers, then offer them ?150 and save yourself some wedge
They did do the Mk1 Cabby over there as there is one in Shallow Hal but I suspect those coilies won't go on it.
Sorry but ?43 including delivery from America? Doesn't the phrase "If it sounds too good to be true, it probably is" feature here.
You'd be better off spending your money on non-adjustable lowering springs from Euro Parts. 40mm items will pair up fine with standard dampers.
thanks
joe
Joe
its nearly sat on the floor at the back end at the moment,think the shocks might have gone but not sure if the previous owner as messed with it. the front end is high.
i was thinking of getting adjustables so that i could mess with the height.
but i think standard shocks might be better quality than a cheap set of coilovers?
Joe
Fit a reasonable fixed height lowering kit and the car will be transformed.
A 40mm drop on 185x55x15 should cause no issues.
so all in all
it'll cause no real problems if i use 40mm lowered springs with standard shocks front and back even with 20mm spacers on the back and 10mm spacers on front
or could i go wider on the front
Joe
youve been a great help
ive just got to get her runnin sweet now
thanks chris
youve got to laugh
think ill give the septics a wide berth thinkin bout it
Joe
needs 3 out of 4 corners spraying as well
any idea what the measurement should be from the centre of the wheel to the underside of the arch when standard
does it looklike its been lowered at the front already
Joe
