Another one fails!
(In Topic #74331)
Another one fails!
Been to busy working to sort it out for re-test and have had to decalre it SORN as tax just run out. Off on holiday soon so will have to wait a couple of weeks before work can start :roll: . What's more its all a bit to near the fuel tank e.t.c for me to feel comfortable welding. So I'm going to gave to drop the axle, back box, tank, filler/breather pipes and fuel pump - which should be fun.
Actually looking forward to it all bar undoing the nuts on the axle/chassis studs which hopefully won't shear :pray: . Decided may as well crack on with sorting out O/S rear inner arch and spare tyre-well while cars stripped down. Also will paint rear axle, re-furb rear brakes… maybe some new bushes… Hopefully, get it back together in time for Gaydon.
1983 1100 C
1983 1100 C
Ii know what you mean………. mechanics can be enjoyable it's just those god darn seized bolts and dirt that spoils the fun!
Hope to see you at Gaydon :wink:
be a good time/chance to get some WD40 sprayed up on all the nuts and bolts you'll be removing so it can soak in while your on holiday!
Hope it all goes smoothly for ya!
1983 1100 C
1983 1100 C
1983 1100 C
1983 1100 C
1983 1100 C
1983 1100 C
Life Member
