0/60 techniques pls
0/60 techniques pls
what are the best techniques to get up to 60 from a standing start then!
obviously avoid the dreaded tyre eating wheelspin but after that??
rebuild in progress....
stuff a 4wd 5 litre audi rs4 quatrro lump in it that shoulddo the trick :mrgreen:
J.
1982 Non Sunroof Black 1600 GTI
2003 MKIV Golf PD150 GT TDI
should i do that after the wheelspin........
:mrgreen:  :mrgreen:
no seriously, ive been challenged to a show down and want to know whens the best time to change out of 1st, 4 1/2k or later
its against a triumph bonneville! :lol:
An old bonneville, or a new one?
I seemed to hit 70 fairly quick the other day, pulling away from a roundabout onto a dual carriageway. might have had something to do with the 18 wheeler i pulled out in front of mind…
Basically hit the limiter in 1st,  backfired as i selected 2nd and floored it again. Changed up to third before the limiter.
be interested to hear how you get on… the Bonnie is a bike i reckon would shoot off the line, but runs out of puff at about 90…
'85 GTi Cabriolet
'80 Kawasaki KDX 175
'93 Kawasaki ZZR 600
'97 Chrysler Grand Voyager
its an old one,
i have no idea about their specs.
anyone????
dump the clutch at about 3500rpm and when the wheels spin back out of the throttle until traction is gained. change gear at about 5500rpm and you wont go much quicker. (this is how i pull away from most lights!)
muttley racing ftmfw
when i sprint at pod etc i launch from idle believe it or not  :?
just match pressing throttle down to taking foot off clutch dont hold at anything more tha 1100rpm will take practice but will eliminate spin try it ! it took me a few atempts to get it right but it proved better at pod the first time i put it to use! and also used it at inters which was a shite concrete strip and it worked there too! there is no need to launch from high rpm all you do is introduce traction problems as you are alredy nearing peak power, yes i has some slight spinning but nothing much , i had slight spinning as i changed into second at around 5700rpm (seems to be the best rpm to change from 1st to 2ndand 2nd to 3rd  but take it to limiter in 3rd and int 4th)
i ran a 16.2ish before this technique (standard mk1 8v except k+n filter and supersprint exhaust) and with the new start and earlier shifting i averaged 15.7 thats half a second quicker that is a lot when it comes to 1/4 sprints :wink:
hope  i havent confused you
ps same technique with a 16v mk1 (157hp) only ran 15.5 dead and 7 dead to 60!
if the sumps not dented its not low enough
standard origonal 82 mk1 jetta c     for sale
thats good info im gonna practice both techniques and see which suits me n the car best,
i still havent got this guy to commit yet i wonder why…..
Id start by taking all the bodies ou the boot and then just rag the grandmother out of it !!!!
Sorry mate , another cheap shot i know , couldnt help myself .
Will the triumph , triumph over the golf  ???
DOH there i go again im gona go away now and have a curry  :mrgreen:
