mobile Mechanic/forum user needed Rochdale
(In Topic #192354)
Need mechanic/forum member to do the cambelt/ timing and dizzy setting up. Will have to come to me i live in Bacup near rochdale will pay.
Or can any one recommend someone to do the jobs
Do you have all the parts to do it?
I may know someone who may be able to do it for you, I would have to find out for you.
I would do it myself, but don't like the idea of doing timing belt on someone else's car, incase there is problems.
Or the garage I take mine to for mot etc, when I don't do the work myself is very close to you.
Hi pal thanks for the reply. No I haven't bought the parts yet but that's not a prob. Still trying to suss why it isn't startin was fine last month think the ignition timing is off. Where abouts do you take yours for mot? Problem iv got is getting it there. Car was fine I don't understand it.
Hi,
Though it might be a problem getting it there after I wrote it. It's shore service station in brittania/shawforth. I got my timing belt on the mk2,done.
What is the car doing? Is it running at all? Have you messed with any of the timing? Is it just turning over and not firing?
It's unusual for ignition timing to go off enough for it to start one month and not the next. I thought I had the same problem when getting my car started after sitting for years.
It wasn't until someone on here asked if I had been messing around with the plug leads, that I realised I had put them back in the wrong order, thought I would post just in case…..
Yes its turning over but not starting. I have changed dizzy and new leads. Should the rotor arm be facing the little mark cos it isn't. Shore service is only 2mins from me so that's good to know. Was it recently youve had work done there?
has it stopped before you changed the Dizzy? or since?
Regards Volkswarren
http://vwgolfmk1.org.uk/index.php?page=cedi&type=misc&id=144
Try the link above, shows you how to do the dizzy and leads. I think the rotor arm is keyed so can't really put it on wrong. Are you sure that you put it all back on in the correct order?Have you had a timing light on it? Have you also checked the coil. When mine did that it was the coil.Can't really see it being anything to do with the cambelt, if you haven't messed with it. Cambelt was done a couple of years back now, but I've been going there for about 20 years, johns ok.
Its running my bad was setting leads the where the rotor arm was. Thanks for the guide link. Defo go down the road for cambelt to be done want kinda price was it can u remember?
Not too sure now, think it ended up being about a hundred, as it took about 3 hrs from what I remember. One of the pulley nuts were dead tight and took ages to undo. I supplied the parts. Probably do it myself on my others, but needed that one doing pretty much straight away
