Mk1 Specialist Garage - London Area
(In Topic #90211)
I just wanted to know if you could direct me to a reliable specialist garage within the London Area (and Greater London) that can undertake some work on my newly purchased MK1 Golf Cab (G Reg) Auto.
The kinda work I need undertaking is (although not limited to):
Full Service and MOT
Cam Belt Check and Possible Replacement
Dull Brakes/Disks/Pads/Fluid/ and possible servo and master cylinder replacement (although I'm not expert - matey-matey advised this!).
And some cosmetics:
Central Locking
Install Auto Hood
Install oil/volt meter/pressure dials
Fit new Hood Tension Cables
New Dash Light as I cant see the Green on very well!
Any ideas/recommendations and suggestions would be warmly welcomed.
Thanks in advance, J
Buy a Haynes Manual or a Bentley one and read up. I'm far from being mechanically expert but lot's of things are worth a try.
Tian :wink:
Although I'll try and find a local garage/mechanic you can?t be too careful as they may try and rip u off with such an old car. But I guess I have no choice and will attempt to find a local reputable one, since lack of response from this post indicates that no specialists exist.
I do go to a guy I've been using for a few years now for most of the work I can't do myself and if you want I can give you his number. I use him because he works on a mates Merc that's about 40 yrs old so if he's good enough for that he's good enough for my Golf. He's based in NW London so if that's local enough for you let me know and I'll PM his details.
Tian :wink:
