hood sell/fit??
(In Topic #121932)
hood sell/fit??
My gti needs a brand new hood. can anyone recommend someone please?
Member of the month GET YOUR SAY IN NOW
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=86608&highlight=
appreciated, i'll post up what i find.
to now:
Nottingham based 01159214929 OR 07710238088 - £425 Fitted and will come to me
Northern car hoods - £420 Fitted with discount for being a member on here which is £15 on top, so £435 all in but you get membership/extra benefits
will update when i get more prices.
cheapest vinyl quote is £320 fitted.
i really like the mohair and i reckon its alot easyier when it comes to folding etc and probly better in the long run compared to vinyl
but i quite like the look of vinyl on the older style of car compared to mohair just looks slightly out of place maybe a poll on this one lol
they did a very good job of it! place near chessington
Any other options that are cheaper are very much appreciated!!
Cheers, Steve
you can fit yourself as I have just done, but it took me a while to do.
You can pick up a vynil hood new for £129.00 from BAS international who supply a lot of the fitting companies.
The side tensioning wires are connected to 2 nipples on the hood frame sides near the front.
They then pass through a slit in the hood sides and down into the last section of the roof frame, through an eyelet and then attatch to 2 springs that are located on tabs.
Some cables are pre made and some come as a length of cable with clamps that you need to crimp once you have made a loop.
I have followed the guide from the link on the left and managed to get the old roof off and the back window out. There is some rust on the lip on the inside of the window surround, in a few places it has rotted to nothing but most of it is rusty but salvagable. As long as I Kurust and hammerite it I am hoping it will be ok… I'll try and upload a pic.
Also the padding under the vinyl seems ok but there is a thin, purple/pink silky material on top of the horse hair matt that is ripped and quite brittle, could i get away with cutting this off and gluing (around the edges) a new piece of similar material over the top? I presume it is just there to stop the two materials rubbing.
Cheers y'all, Dub
They are usually stiched onto the side black vynil bits.
I would reccomend that you repair this in some manner.
Mine was replaced with calico.
If you could machine it in then even better, but that means more stripping down and sewing.
I pressume that you may be able to glue some other material to it, but the stuff on at the moment is similar to parachute silk!!
I replaced the whole lot from headliner upwards.
The frames are available from QC or message Funkstar on here to see if he has a spare.
Personally I would put a replacement frame in, I got mine from Crazy Quiff and swapped the insert over.
You would need to use tiger seal to glue the insert back into the new frame.
The rubber seal it's self goes around the rusted bits you mention and you may have a problem with the seal fitting correctly. I pressume you could weld some more steel to it, but the one I had from Crazy is stainless steel so no more worries there.
Piccies of the frame would be good too.
What glue are you using? you will need to glue parts of the hood to the frame.
I have sent you a pm to help.
Thanks for the offer of help but Bristol is quite a trek from Derby!!
Here are a couple of images of the rear window surround, it isn't as bad as I thought, its quite corroded in a few places along the bottom but the ridge is still fine on both sides and across the top…
Fingers crossed that with some proper treatment it will be ok :? I don't think I can stretch to another £125!!
Also I have taken off the old material from the top and the rest of it looks pretty good, i'll have a look for some calico and try and stitch/spray glue it in place.
What glue would you recommend and also where would I get the adhesive foam strips from?
Sorry for all the questions!!
Cheers, Steve
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=220255351546&ssPageName=STRK:MEWAX:IT
yep it looks reasonably good.
which foam strips? the one that runs across the front and the rear?
I just bought some thin foam from the foam shop, it's the stuff they use on ironing boards, I just cut some strips out and glued them in place.
B18DUB said
So do you think the frame is salvageable?
Mine was a bit worse than yours.
it would be hard to tell, try your seal up against it now the rusty bits have fallen off, should give you an Idea of what will fit where. The seal fits over the lip part and may not sit properly, plus how stable would the window etc be?
I would pm Funkstar and see if he has got a decent frame in and swap em over, that bit is easy.
Where the top straps that go to the top part of the window, push them out of the recess of the frame, there should be a plastic rod that goes through these. Simply push them out and slide the strap back through the slot in the frame. Refitting is the reverse.
The bottom section is just held on with 4 bolts.
The hood thing allway's seem to open a can of worms.
It would be a pity to go through all the hood fitting only to find the frame needs to be replaced, if you don't replace it now, you will have to replace it at some point which would mean undoing all your hard work.
Tough decision :dontknow: :dontknow:
I know what you mean about the distance, if you were a bit closer I could of popped over.
Slight problem is, I'm in Guernsey, and I don't think the place we have would have much experience of this, being more used to making boat covers etc. I've e-mailed the Carhood warehouse recommended in the guide, as they have recommended fitters. I could get to Poole or Southampton by ferry, so I've asked if they have anyone in that area, where I could travel over for a weekend. Has anyone any experience of firms in that area?
I've got to the stage with my car where I either need to sell it or spend a bit to get the roof and bodywork done up. it's done about 95,000 miles in its 19 years spent over here, doing short journeys and not going over 35 mph ( in theory!). I got some leather seats on e-bay to replace the cloth ones, and managed to fit them myself, though the rear seat still looks a bit naff as it was from a tin-top and I had to … errmmm… convert it a bit! 8O
Any thoughts on the hood would be welcome!
Yes it is time consuming but satisfying when you have completed it.
good luck as to what you decide to do, but a good roof is money well spent.
