Wont start, HELP!!!
(In Topic #111049)
Wont start, HELP!!!
I have a 1800 8v gti cabrio 1989.
Last week i changed the distributor cap, rotor arm and ht leads (all with genuine parts). At first it ran very rough as if on two or three cylinders, then an almighty bang from beneath the bonnet. It will now turn over but wont start, it wont even try to start. I am sure the order of spark is good (althought could someone confirm what lead from cap to what plug). The fuel pump is buzzing okay.
All this because whilst changing my gear linkage i lent on the old cap and snapped off an ht lead.
Thanks for any help.
Bez
I think that all looks good. I have removed an injector and i dont seem to be getting fuel in. Maybe load bang has blow things. I can hear buzz of fuel pump thou. Is there a fuse or relay to check?
Bez
I can only think this is connected somehow to loud bang i heard from under bonnet. I will check for a spark tomorrow although i am concerned that i have no fuel, I will also remove fuel pipe just before filter under bonnet tomorrow and check for supply.
Thanks for help and will keep you updated (all this cus i cracked a bloody ht lead working on something else).
Bez
