Which fuel tank for abf on carbs?
(In Topic #148635)
Im putting an abf on twin weber 45s into my golf , just wondering which fuel tank is best to use. I'm thinking of running an external swirl pot with a facet red top main pump and a facet silver top for the swirl pot feed as the cars going to be used mainly on the track.
Sam
Sam
You can use the standard GTi one, or get an alu race tank
Birmingham
s
ahh cool, so if I had a carb tank I can just run the swirl pot supply and return from the two outlets on the sender unit?
i would get a later cabrio/scirocco or g40 shape polo lift pump to feed the external swirl pot. these models also have a suitable swirl pot you can use. depends on how well the silver top can keep up with the demand and how well it can suck fuel up out of the tank though
nice one, so a gti tank and polo g40 lift pump to the swirl pot and a facet red top for the main pump?
if you use a gti tank no need for the lifter or external swirl pot, as it already has an internal swirl pot.
if you have a carby tank, then fit lifter pump and external swirl pot
edit: and any g40 shape polo will do, even poverty spec. they all have injection so have lifter pump and swirl pot
edit2: you may find the lifter pump on its own can supply the carbs ok, not 100% on that one though
cheers chap well appreciated, il see what I can find.
