whats wrong with my car????????????
(In Topic #94308)
ive got a mk1 caddy, the problem is if i drive on the motorway!! or start giving it beans for anylonger than 30 seconds or hold it over 3000 rpm.
it just holds back and wont rev or do anythink
if i leave it on tick over for a second its fine untill i hit 3000 rpm!!!
ive cleaned the fuel tank replaced the filler neck cleaned fuel lines new carb and filter!!!!!!!!!!!!!! no change
changed points condenser timed engine with timing light!!!! no change
good compression, good spark, got air and i can smell fuel
does anybody no if there is a problem with the manuel fuel pumps!!
please help
i always have the last laugh
<a href="
http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg<a href="
cheers simon!!!!!
ive been looking through the FAQ section an a few people had a similar problem and they changed their dizzys an it was sorted, somthing to do with the hall sensor iirc, im gunna try that and see if it helps. ill let you know how i get on
pete
Prowler said
How about rotor arm….if you have one with the rev limiter on it GET RID….they cause all sorts of probs….
do that! first thing i do with a new mk1.
it's not actualy freezing, it's where the fuel is too cold. the fuel needs heat to gas. connect the heater pipes all back up and see what happens.
THE BAD NEWS IS:
but doing all of this makes it run like a bag of arse!! untill it warms up! then it runs as sweet as dream!!
GGGGrrrrrrr!!!!
its A 1600 WITH a carb!! dont think that the auto choke could be playing up now!!
if so does any body no the lay out of the vaccum pipes on the back of the carb and how the auto choke works!!!
first flush the water system. then check that the auto choke is clean. then check the vacuum system has no leaks.
also check that the preheater (if it has one) is working.
