What does the swirl pot look like and where is it in the gti
(In Topic #110178)
I have recently bought a tank and was told its for a gti with a swirl pot. I have looked inside the tank, but im still not sure if it has one. It has somthing directly below the sender?? but i was told it should be located near the bottom pump supply pipe. I have a feeling that what i can see is just a filter or somthing??
Many thanks
Gurj
Many thanks
Gurj
Never heard of it fitted as standard to a fuel tank :dontknow:
Yeah, i been told that only gti's had a swirl pot located in the tank to stop fuel starvation when cornering. Thanks for the reply.
Gurj
Gurj
Could be the cone just under the sender hole. The return line feeds into the top of the cone in such a way that the fuel will swirl around and down when the fuel level is low. Never heard or thought of it as a swirl pot?
all fords have a swirl pot in there injection tanks, as said it is to stop starvation wen cornering you would have to open up the tank to see it i think mate
