Warm up regulator???
(In Topic #90652)
Hi there, just a quick question to see if anyone can help me.
My car - Mk1 GTI Cabby on a C plate - is a nightmare to start from cold. It takes 2 or 3 turns at least and that's on a hot day. Basically there's no choke at (the choke is supposed to be automatic.) Someone told me it might be the warm up regulator. What I wanted to find out was how easy it would be for me to change the warm up regulator myself - I'm not that mechanically minded but am willing to give these things a go - and where it is located. Any help would be greatly appreciated.
Robin
Robin
Very easy its mounted on the front of your engine with 2 fuel lines going to it and just a couple of Allen bolts, shouldn't take longer than 30 mins.
Cheers, for that. Will give it a go!
Make sure you get new copper crush washers for the fuel lines else you will have fuel leaks...
check the leads going to said regualtor, if they are bare or worn you wont need to replace it - bit of insulation tape will do the trick
Hang on there….
First thing I'd be doing is checking the operation of the Cold Start Valve - the one on the end of the inlet manifold.
It is supposed to fire fuel for 8 secs when the engine is cold.
The warm up regulator richens the mix after that until the engine is fully warmed up. soooooo if it is a problem on the initial crank I'd look at the CSV.
Rich
Rich
Are the warm up reg adjustable, mines very spluttery until fully warmed up but has recently had a new wur.?
Soory dont wanna hi-jack.
<a href="Image hosting, free photo sharing & video sharing at Photobucket"><img src="http://img.photobucket.com/albums/v312/biggaz/hezzasig.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
mk1 Jetta GTI Spec.
mk1 Jetta GTI Spec.
No - well, not easily. If the WUR works properly, you should be able to set the mixture so that performance during warm up and also once fully warm, is acceptable.
Cheers, its very lumpy and like a carb with no choke when cold, untill FULLY warm. May try find a one to swap it with to try. The fast road cam wont help but ive had a similar setup before and it was fine.
Thanks again, sorry to jump in.
ops: gaz.
ops: gaz.
mk1 Jetta GTI Spec.
mk1 Jetta GTI Spec.
I have a new old stock regulator still in VW wrapping !!!
If its the one you want, make me a offer!
HAVE VW ETKA 7.0 SO CAN HELP IF YOU NEED A PART NUMBER FINDING. PM ME.
