WaaaaaWrrrrrrWaaaaaWrrrrrr A surging Driver
(In Topic #131977)
have you had the carb off recently? Did you inspect the rubber mounting gasket? These are prone to splitting, meaning the engine can suck in air, which is not having fuel added via the carb, causing poor idle.
My Build Thread
I had a problem with the carb icing up due to the flap in the air intake sticking open. To cure it in the short term I jammed the flap shut so it took air from the top of the manifold until I could get it fixed properly.
