unknown engine part???
(In Topic #118704)
Have just noticed that the pipes had been swapped over. Any ideas what symptoms this would produce?
Much appreciated.
Oops.
next question(s)
2. What does the diaphragm pressure switch do?
If you mean the metal thing behind airbox with a vac line and a 2 pin plug, thats the cold throttle enrichment valve. it gets 12v from the throttle switch when throttle open, and sends 12v to the 5th inj when a hard throttle condition is detected. the 5th inj earths via the thermoswitch, so this will only happen when the engine is cold.
If it's aircon then yeah it's to increase the idle when you turn the aircon on to take up the load the pump puts on the engine.
Jon.
