type of fuel?!
(In Topic #118065)
type of fuel?!
this might sound like a daft question, but does my 1987 1.6 run on unleaded or on 4 star?? i know the older cars did and you need buy the additive.
run it on 97/98 ron and you'll be fine
Nice one. Been having a lot of trouble with my car, and it's oftern the simple things like that are over looked!
yep, 95 shouldnt cause to many problems for a short period, but id always recommend higher octane where possible. i certainly never use less than 97 ron in any of my vehicles. i even run super diesel in my van, not that it makes much odds in a 3T van!
Hi
I run my mk1 on 95 , can someone please explain in some detail why this might be wrong , the car goes very well
baz
baz
is it a gti?
if so it was designed to be run on higher octane (4star) fuel and so should really be run on higher octane fuel now.
higher octane reduces the risk of engine knock/pre detonation/pinking.
see here:
Fuel octane ratings explanation and compared.
see here:
hi
yes its a 1.8gti tintop
thanks for the link
so did 4star leaded have a 97-98 octane
or am i missing the point
baz
car sounds & goes great on the 95 , but maybe i am causing long term damage :?
thanks for the link
baz
4star will have had a higher octane rating than standard unleaded i believe yes.
i ran my mk2 1.8 on 95 ron until i started tuning it, then i switched straight onto 98ron. i have a mate who has only ever run his g60 on 95 ron, hasnt caused any damage but after a little while on 98 he agrees its made a nice difference.
googled leaded petrol octane & yes it is the same octane as super-unleaded
so maybe i should start using super-unleaded - but even the MPG on my mk1 is excellant on the 95
but if it is causing long-term damage i will be def be changing
baz
baz
the higher octane should also see better MPG
Your mates g60 would have been fine with no damage as it has a knock sensor which detects low octane fuel and retards the ignition till the nock is gone!!
On 95 he was prob down 15-20 horses!!! No wonder he agrees it's better on 98!!!
My formel e has a sticker behind the door saying 98 only!!! and it's only a 1.1.
Jon
Jon
My 1.1C has a sticker too and its says min of 91! I always use 98 in my 16v tho!
hi
so am i the only one that has been using 95 ???
- going to start using super-unleaded now just incase i am causing excess wear&tear
baz
baz
I'm sure load of people use 95!
Jon
Yep, the C formel E engine was a high compression 1.1, so it needs 98RON petrol.
