trouble at full throttle when warm
(In Topic #142976)
i have a 1.8 carb cabrio and have only just put it on the road. driving locally it gives me no problems, took it to a show at the weekend and along the dual carriageway at full throttle it stutters and if yuou dip the clutch cuts out. I restarted it and feathered the throttle back up top speed and it runs fine until under load i.e up hill or flat out
any ideas? im not familiar with carbs tbh and i have fitted a k&n bolt on air filter instead of the airbox. I have been told about carb icing but does this normally happen cold? its had a new in line fuel filter but it never fills up could this be the problem?
any help much appreciated
Dale
http://www.clubgti.co.uk/forum/showthread.php?t=144497
will stick the ugly airbox back on and see how she goes
its like its not getting enough fuel at WOT because it will run for days and days cruising but if i have to put my toe down it cant cope
any other suggestions? since replaced fuel pump and it has already had new plugs, leads,cap and rotor arm so i believe its fuel related.
is there any adjustment on the carb to let more fuel in? just think IMO its not getting the fuel it needs
I would check the fuel tank and pick up jobby in the tank for blockages/restrictions, sound like something simple dunnit?
if that lot doesnt work a can of petrol and a lighter lol
cheers mate
i dont want to take it to a garage and spend hundreds and still have trouble but all the mechanics i have meet have been pants seems there are no good mechanics any more.
and blackcherry it has been driving me mad as i dont dare get in the fast lane. will let you know how i get on replacing the vapour seperator and trying what dunk70 said with a second filter
cheers guys
Dale
I did this and went out on a little run up some rather steep hills which i knew the car would have problems going up on full throttle but to my surprise it flew up no problems not even one cough or splutter i even thought with me nipping up the pipe that returns to the fuel tank it would flood the car on tick over but i had to stop at a number of traffic lights and it ticked over fine the car used to tick over at 1500 revs now it ticks over at about 1200. So my problem seems to have been sorted touch wood
And rubjonny I sucked the vacuum pipe and the flap moved so I'm assuming it's doing it's job?
Thanks for your ideas/help guys
Dale
problem solved me thinks..well am leaving it like that anyway
cabbydale said
Cheers wardy if you could let me know what happens that would be brilliant. Not sure how it will affect fuel economy by removing return pipe?
Dale
may be worth checking?
and mine has new everything bar dizzy on it blackcherry so will make sure thats timed up and working correctly cheers mate
dale
