Tank Filler Neck Fitting - Helpppp!
(In Topic #161136)
I brought the below tank filler neck
http://www.ebay.co.uk/itm/350532162470?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
I have spoken to the suppliers they said it is for a mk 1 golf, but i need to do some modifications to it….Does anyone know like what??????
1985 Cabriolet GL
Julesgreycab said
Do you have a cabriolet? As these I believe sit at a slightly different angle in relation to the panel than a tin top, this might be the mod required.
Hi mate, yes it is a cab….
i have looked at the other ones on ebay that claim to be for a cabby but they look the same as the one i brought mate…..
keep at it though…
Website Manager
Space saver wheel, large fuel tank, full size spare wheel, small fuel tank.
Make sure you paint/treat the new filler neck, the paint which is on there when new wont last long.
http://www.rust.co.uk/products/category/28117/epoxy-mastic-rust-proofing-chassis-paint/
Once it was dry (left it for a week) then sprayed on some ratel can stone chip paint.
Hammerite Stone Chip Shield. Spray Shield Underseal Metal Paint for Cars. Underbody Black Metal Paint. Rust Resistant, Durable Automotive Paint, 8 Year Protection - 600ml Aerosol 1.5 SqM Coverage? : Amazon.co.uk: Automotive
(first web link I found so you might find a better price)
I then brushed on some white hammerite paint, I have a white car just to match the car colour. (not the best paint to use on its own)
http://www.amazon.co.uk/Hammerite-HAM6720201-250ml-Metal-Paint/dp/B001GU8C8U/ref=sr_1_3?s=automotive&ie=UTF8&qid=1375914123&sr=1-3&keywords=hammerite
Then once fitted I sprayed waxoil all over the filler neck.
I brought a new filler neck 13 years ago for about £75 so wanted it to last so I might have gone over the top with paint/treatment but I use my car all year round as its my daily drive. After the 13 years its been on the car the white hammerite has chipped of in places, I do waxoil the filler neck and car every couple of years and clean regular with a hose pipe under the wheel arches so there is still no signs of rust on the filler neck, it should outlast the car!
