supersprint middle section
(In Topic #75557)
I've just bought a group a supersprint backbox, will this fit onto my mongoose system?
Also is it illegel to run just 1 silencer?
I plan on having a straight through system with just the rear box at the back…
:dontknow:
1272 driver with a magic tree!!
is anybody on here running a straight through pipe….?? i just want more sound…can you modify an aftermarket system or am i best going back to a std system then adding a straight through pipe…
MOT testers don't usually test for noise unless they think it is excessive. You will only really have a problem if the rozzers take a dislike to it and pull you over. Will only give you a producer to get it fixed though…
As for fitting you mongoose system, the joints might not be in exactly the right place, though you should get it on. If the diameter is not the same you could use a step tube. Be aware though that the Grp A system is mild steel and you Mongoose is probably stainless. They don't joint very well and may start to blow a bit every now and then.
My Build Thread
Im not sure if im going to like the sound of no center silencer though!?? i'll most likely be selling the mongoose at some point though so i dont have to butcher it to get the supersprint on…
Should i get the straight through pipe or should i buy a std gti system with the middle box in?
please help!!!!
ssshhh…dont tell any1 tho'
:wink:
Incidently the system was noise tested at a track day at Castle Coombe this year at 94db
MK1 Golf GTI 1900
MK2 Jetta GTI 16V
MK2 Jetta GTI 16V
Anyway i've orderd the middle section from halfords, and it should be here tuesday, will it be the same size as the bore on the exhaust backbox?
i've got the exhaust on, with a straight through pipe and it sounds sweet!! Everybody thought it would be to harsh/chav-ish and unbearable… well even though its only got the rear box it sounds very quite, just what i wanted, at idle it has a tone and sounds 'sporty' when you boot it! not nova/corsa-ish AT ALL! Get rid of those middle box's lads! :wink: :mrgreen: you can even tell a differance in performance
:mrgreen:
