struggling to start up when warm
(In Topic #132543)
my cab starts first time every time now i changed plugs, leads, dizzy cap and rotar arm but when its been running and i try again after like 10 mins it seem s to struggle and turn over alot before ignition? The fuel filter in engine bay seems to be pretty much filling so is it pulling in too much fuel and flooding as a result?
MK1 Cabby '90 R.I.P
'83 tin top gti
'83 tin top gti
Pal i had a mk1 years ago that was exactly the same i changed lots of parts fuel pump , one way valve, accumulator etc, i then changed the metering unit, this cured the problem, my car was always a first time starter from cold, soon as it was warm it started after lots of cranking almost like it had to build up pressure hope this helps
My cab use to be a pain to start when warm, it ended up being a leaking injector, which would flood the engine if you didn't catch it on the first turn of the key.
Come to think of it tho, this would sometimes be the case when cold too.
If your still having problems maybe get the timing set up with a timing light?
06 Audi A3 (Wifes daily)
hi mate my 1990 cab is doin the same one chap on forum told me to change metering unit thats what you and i should do it really does my head in
a.s
hi thanks for that, im going to satrt by changing the metering unit myself so if that doesnt solve it then look at then injector side of it, its frustrating knowing it starts fine but when it struggles and you have a snob in his merc watching it struggle.... haha
MK1 Cabby '90 R.I.P
'83 tin top gti
'83 tin top gti
Where can i get a new metering unit from new? cant seem to find one anywhere on web?
MK1 Cabby '90 R.I.P
'83 tin top gti
'83 tin top gti
