Strong smell of fuel
(In Topic #74034)
My x reg Mk1 Golf cabrio has recently developed a strong fuel odour. Anyone know of any problem areas which usually occur or where I should start?
Ta.
If you leak fuel when you fill the tank to the brim but then it stops after a short time/travel then this is probably it
Hairyarse said
Apart from obvious checks - i.e. looking for leaking pipes, fuel filler neck, fuel tank etc. I had fuel odour in my MK1 once, it turned out to be the O-ring seal under the sender unit on top of the fuel tank.
ah ha! this is wot i have!
although the oder is still about but not not as strong! i was thinking its leaking at the seams, prob is there are no real leakage signs!
Hairyarse said
I was surprised how much the old o-ring had ballooned in size! 8O
im on the case!
just gonna go and fill er up now the cover is off and see how much it does leak from there…
can i only get this from vw as i would like this for sunday but im at work…
cheers boss!
cheers hairy!
hope the gearbox whine will dissapear with the additive i bought too, or is that pushing it!
off to vw for the seal now, wooohoooo!
Hairyarse said
Do Halfords do a multi-purpose O-ring that fixes all faults with a Golf?? :dontknow:
I'm sure they'd say yes though and give you a jubalie clip and say that its round and adjustable!
….Just got my new 'O' ring from my local friendly VW Specialist - Volksline' in Canterbury - just over ?50…..!!!!!!!
BUT…..
I did also get a new Ernst rear box….
….AND a set of injector seals…..
….And new air filter…..
….AND……..I HATE going there….always spend more than I intend to….
