Strange GTI fuel pump noise......
(In Topic #74052)
…sometimes, when braking and stopping (at traffic lights, parking etc.), the main fuel pump changes pitch (higher) and sounds like it's getting air in it……sometimes the engine actually cuts out…..
..has happened under hard braking, but not on hard acceleration….
Initially started to appear when down to half a tank…..
Now at 3/4 tank…..
Main pump (and fuel tank/filler neck) 3 years old
Lift pump 18 months old
I am thinking that the hose from the lift pump is split……allowing air into the system when the fuel in the tank shifts and moves the lift pump/sender unit…
..am going to check it out later today, but anyone got any other ideas ?????
had a similar problem with my cab - got a load noise from what seemed like the pump but is was actually the pipe from the accumulator vibrating - caused, I think, by an air lock or water in the accumulator - gave it a good clean out and problem went away
This is what I found when I took the lift pump out…………..
……….just look at the crud on the filter….
The tank was swilled out before fitting,
I have been VERY careful when filling,
it's non-metallic,
and there's tons more of it in the bottom of the tank.
DIRTY FUEL ??????!!!!!
…after cleaning…..
sounds and goes better so far….taking a spin later…so fingers crossed…
I don't think you'll find the lift pump on your tintop.
Prowler,
Man that is dirty - didn't remove that from my car - maybe need to have a look!!
Dirty fuel is a real problem - I filled a petrol can from a station and put some in my lawn mower - found that it had about 1/2 pint of water in it!!!! Suffice to say the lawnmower didn't run very well
I need one for a conversion on my clipper ya see.
1982 Mk1 GTI 16v Mars
1978 Mk1 GTI 1.6 Mars
1975 Mk1 LS
1996 Mk3 Cab VR6 Turbo Project
1998 6n Polo Black
1984 UR Quattro Red
1961 Lotus Elite Silver
Mk1 & 16v Golf's Breaking for spares
1975 Mk1 LS
1998 6n Polo Black
1984 UR Quattro Red
PhillTMK1GTI said
8O was it easy to remove the lift pump?
Very easy…(This is only on later GTI Cabs I think)
Remove rear seat squab.
Remove this plate…(3 screws - 2 already removed)………
Remove the electrical connector and undo / remove the supply pipe (lower) and return (upper)……….
USE A WOODEN DRIFT to knock each of the lugs to rotate the whole assembly (yes - I KNOW I have not removed the pipes !!!!)
Wiggle the assembly out - it JUST fits the hole……
…..check the big 'O' ring….must replace mine….just found where fuel was leaking when the tank's full !!!!!……….
The filter pops off with the help of a small screwdriver.
Websnowbo said
When you bought your new lift pump, did it come complete with the sender etc
…pump on it's own with filter attached.
Anyway, I now have, as said in another post (about the fuel pump filter)…
"1.8 ltr of pure BEAST"!!!!
The difference that stupid little filter made!
Just been for a 'quick' blast (about 30 miles of pure fun)…..I did not realise how much power was missing - I normally drive like a tortoise - but not tonight !!!!! :twisted: :twisted:
that seems to be very empty
1983 1100 C
1983 1100 C
took it all off and what I had was.. well, not that! in the haynes manual it looks like I've got the same as a Scirroco :dontknow:
No filter there at all, looks like the only thing there is the Fuel gauge sender unit!
is this right for my car? 1600 '82 GTI
You will only have the sender in your tank.
The fuel exits the tank through a gravity fed tube in the right hand corner where it attaches to the pump. You then have the little filter, like I found full of crud on mine (other post), and then the big silver filter at the metering head.
My Build Thread
1983 White cabriolet GTi
well seems to be running well at the moment (still need to tune the timing a little I think) and just put a new fuel pump on and drained the tank
so I think it should be ok (unless the new pump didn't come with that little filter :scratch: )
didn't like the look of inside the tank, the sender unit was really rusty and suprised it still works! and the tank looked, well… Mank! going to treat it to a new fual tank and sender unit if it gets through the MOt without too much of a headache!
I just bought a dog of an 86 Cabby (Cheaply thank god)
The fuel pump sounds like a Clifford alarm on start up and it doesn't like to stay running when cold - when warm idle is about 2k
Where can i find/what does the accumulator look like?
