slight hesitation on full throttle. new weber carb
(In Topic #97008)
Basically fitted a webber and the car runs and idles well. However when i boot it there is a slight hesitation, it almost feels like its about to cut out. Then it revs beautifully. ANy ideas. Ive changed the dizzy cap, forgot the rotter arm , spark leads, plugs and what have you. Could the timing be out, its an 89 carb? Also that bracket u fit on the webber to hold the airbox seems to be pretty pants, as it overlaps one of the flaps slightly if u fit as directed, i have my airbox at a slight angle towards driver side to make sure it doen?t. Anyone got a pic of this bracket fitted to the webber?
Golf Clipper 1.8 Carb F Reg in Blue
mods and work so far:
mk4 rear disk
vr6 calipers and g60 disks
9" servo and 16v master cylinder
h&R adapters and d90?s 6" front 8" rear
webber carb
inlet manifold, rocker cover & exhaust mani gaskets
mk4 rear disk
webber carb
sounds like ignition. try a new rotor arm, points and gap if applicable and timing. then set the carb up again.
new plugs leads etc will only help
mk4 rear disk
webber carb
mk4 rear disk
webber carb
mk4 rear disk
webber carb
mk4 rear disk
webber carb
If the carb is brand new, the jetting should be OK from
your supplier, but it still might not suit your engine.
The webber is really set up by changing the jets and
emulsion tubes for each trottle body. Mine did exactly
this until I got the jets sorted (Cheap and easy job).
It's to do with the overlap of the two throttle tubes
and the mixture has to be right for both.
If you PM me your email I can send a sheet of jet
set-up stuff which might help. Crazy Quiffs can supply
the jets.
Beetle restoration. Cabrio GTi (black and shiny). Golf driver.
16v MK2. (Oak green) Now on a Clipper (to keep). Audi A8 4.2 Quattro sport and a BMW R65 bike.
