SImple advice needed about fuel pumps
(In Topic #127273)
I have been told I need to replace the fuel pump (one on the chassis).. but Im finding it hard to find a pump for a MK1 Gti (which is I guess what I need now) - would a MK2 pump for a 1.8i be OK?
Much appreciated for any simple help here
As the Bosch injector system has been added to the engine, I am told any car with this system.. an old Audi, Saab or Volvo will have compatible pumps..
and have been advised to get one that would be able to clout 5bar!
Do you think wooders a Bosch 044 fuelpump will help me here? Would it be easy to install to the Mk1 Golf?? And is all this making sense to you?
Thanks for your expertise on this…
Plenty of cars have compatible pumps but which differ slightly, and those slight differences might catch you out. Also you'll need an accumulator and the relevant hoses. Did they also upgrade the fuel send and return hoses, the GTI uses slightly wider ones? (ie how wide are your fuel lines)?
The easiest way to install it is to copy the GTI setup, ie use a fuel pump cradle, accumulator bracket and all the fittings from one. This might mean welding studs into the chassis/bodywork underneath.
