Rough Idle, 1800 clipper carbed
(In Topic #113938)
My clipper carb, 1800cc has been idling rough lately, around 4-500rpm, occasionally even cuts out.
Is it a case of needing to clean idle jet or adjust idle screw? if there is one? if so where?
The fuel system is clean upto the filter anyway and all electrics are newish
Car works fine past idle speed, and fine on startup so the cold start choke/valve is doing its job ok
still cant find the idle mix screw on the pierburg, any idea?
